Hi guys!
I'm on a roadtrip around Croatia. Yesterday I drove down from Gospic to Karlobag (my God, what a road!). But ufortunately I've killed my front brakes. Does anyone have a spare set of front bigbrakes pads for NBFL 1.8 or could point me to a shop where I can buy it right away (quickly) in Zadar (leaving tommorow morning) or Split (will be there about 14:00) or somewhere on Brać (at the evening)? Any help will be apricited!
My phone number is +48 504 three one two 784
hello
i have some used 1.8 brake pads but they are almost dead and another problem is that i am in zagreb,thats far away from zadar...so maybe is better to try in "tokic" or "autokreso" parts store,like goldin said
Re: Brake pads needed on the roadtrip
#4I've texted you the store and service locations in Zadar and Split. If for any reason you should need additional pads on your return trip thru Zagreb, call me - I have a couple of slightly used sets at home you can have.unaimed1337 wrote:Does anyone have a spare set of front bigbrakes pads for NBFL 1.8 or could point me to a shop where I can buy it right away (quickly) in Zadar (leaving tommorow morning) or Split (will be there about 14:00) or somewhere on Brać (at the evening)?
+385915023331
A big "thanks to all of you" for the responses and the help! I went to Tokic this morning - it was across the street from where I stayed for the last night
Unfortunately they don't have it on the stock. The same applies to Mazda Service, InterCars and Kurona in Zadar. But after visiting all those shops, I finally found Inej Autocentar show in Zarad. They will have it tomorrow morning.
Sash, I've received your text message. If everything goes fine, I'll install a new set tomorrow, so no other brake pads will be needed.
Long live the Roadster!
And all the Croatian "hairdressers"!
