Brake pads needed on the roadtrip
Hi guys!
I'm on a roadtrip around Croatia. Yesterday I drove down from Gospic to Karlobag (my God, what a road!). But ufortunately I've killed my front brakes. Does anyone have a spare set of front bigbrakes pads for NBFL 1.8 or could point me to a shop where I can buy it right away (quickly) in Zadar (leaving tommorow morning) or Split (will be there about 14:00) or somewhere on Brać (at the evening)? Any help will be apricited!
My phone number is +48 504 three one two 784
hello :smt006
i have some used 1.8 brake pads but they are almost dead and another problem is that i am in zagreb,thats far away from zadar...so maybe is better to try in "tokic" or "autokreso" parts store,like goldin said :)
DIJELOVI NA i NB
miata 1.6 NA turbo
mx5 1.8 NB turbo
0915829719
Re: Brake pads needed on the roadtrip
unaimed1337 wrote:Does anyone have a spare set of front bigbrakes pads for NBFL 1.8 or could point me to a shop where I can buy it right away (quickly) in Zadar (leaving tommorow morning) or Split (will be there about 14:00) or somewhere on Brać (at the evening)?
I've texted you the store and service locations in Zadar and Split. If for any reason you should need additional pads on your return trip thru Zagreb, call me - I have a couple of slightly used sets at home you can have.
+385915023331
Sasa
NC RC 2.0 mit alles - #BlackBetty (ZG0504AS)
OLD: 2x NB 2001 1.8 crvena - Sepet(ić) TNG / Sepet(ić)
A big "thanks to all of you" for the responses and the help! I went to Tokic this morning - it was across the street from where I stayed for the last night :)
Unfortunately they don't have it on the stock. The same applies to Mazda Service, InterCars and Kurona in Zadar. But after visiting all those shops, I finally found Inej Autocentar show in Zarad. They will have it tomorrow morning.
Sash, I've received your text message. If everything goes fine, I'll install a new set tomorrow, so no other brake pads will be needed.
Long live the Roadster!
And all the Croatian "hairdressers"! :-D
