Re: SPS Motorsport
#32
This 10th-anniversary NB got in our workshop because on our last trackday in Anneau Du Rhin the timing belt got destroyed by some dirt of the track.
We supposed the valves also got broken because of other camshafts and higher compression, but luckily nothing else got broken.
It is a 1.8L bored to 2.0L with an ITB and very aggressive camshafts. On the dyno it produces 230 natural aspirated horsepower at 7800rpm.
Because of that power and a shorter final drive in combination with a 6-speed gearbox and a shortshifter it is really much fun to drive. :D
Specs:
- 1.8L BP bored to 2.0L with 85.5mm pistons
- Jenvey ITB
- Mishimoto X-Line radiator for Honda Civic
- Reverie RH carbon airbox with custom ram-air hose
- König K 5000 seats
- OZ Ultraleggera 15 inch
Best regards
Guido from SPS
https://sps-motorsport.com
https://sps-motorsportshop.com
https://facebook.com/SPSMotorsport
Re: SPS Motorsport
#33
This is a really nice sleeper setup. A 1.8L NA with a GT3071R turbocharger producing more than 350hp.
The owner doesn't want a rollover bar because he wants to keep the sleeper look.
Specs:
- 1.8L BP bored for 84.5mm Wiseco pistons
- K1 conrods
- ACL main- and rod bearings
- Boundary stage 2 oilpump
- ARP head stud kit
- Garret GT3071R turbocharger
- ATI Superdamper
- SPS oil cooling kit
- Mishimoto radiator
- Skid Nation reroute kit
- 6-speed gearbox
- MiataRoadster short shifter
- StopTech BBK 280mm
- Rota Strike 8x15 20mm offset with Nankang AR-1
- CanChecked Display universal 2.8"
YouTube:
https://youtu.be/DX4rvrRTUKQ
Best regards
Guido from SPS
Re: SPS Motorsport
#34
Hello Guido,
all of these cars are great. And some of them more than other ones.
But, how do you guys register these cars in Germany with all of these modifications?
At the other today's topic here it is reported that technicians for MOT here in Croatia are requesting certificates even for some plastic side skirts...
Re: SPS Motorsport
#35
Your question is good. We have a big collection of documents for all the parts we sell and install.
To register the combination of some parts is also no problem if we look after the laws. Our professionals from the TUV know the limits and look after that. We are doing this for longer than 7 years so we have routine with this issues. We know exactly what is possible to register and what is not.
Best regards
Guido from SPS
Re: SPS Motorsport
#37
Hey guys,
this is our second MX-5 ND. It is wrapped in british racing green and has some cool stuff installed. It is also our first car with a 200hp package with a full exhaust system including race header and software tuning.
It has also following parts installed:
- SPS circuit coilover
- StopTech 280mm 4-pistons Big Brake Kit
- Rays TE37 rims 8x16 25mm offset with Toyo R888 205/50 R16 tires
- Friedrich Motorsport exhaust system
- BBR GTi race header
- Recaro Pole Position seats
- CAE short shifter
YouTube:
https://youtu.be/pgN2g_6ycn8
Best regards
Guido from SPS
Re: SPS Motorsport
#40
Guido@SPS wrote:
1.11.19. 12:53
Until now I didn't know I wanted an ND BRG this bad :smt007
NC RC 2.0 mit alles - #BlackBetty (ZG0504AS)
OLD: 2x NB 2001 1.8 crvena - Sepet(ić) TNG / Sepet(ić)
Re: SPS Motorsport
#43
Long time nothing new here. So there You get a cool customer project. ;)
This 1.6L Miata import got a turbo conversion and has still its air conditioning installed and running. The engine got forged parts and the turbo is an upgraded TD04 turbocharger. Now the engine produces 281hp at the flywheel and 362Nm/267lbft torque.
The specs:
- 1.6L B6 engine bored to 79mm
- JE pistons 79mm
- Cometic head gasket 79mm
- Molnar Technologies conrods
- ACL main bearings
- King conrod bearings
- Upgrade TD04 turbocharger
- SPS 700ccm fuel injectors
- SPS engine oil cooling kit
- Competition Clutch Stage 3
- BC Racing BR-series coilover
- Fender Flares
- Japan Racing JR19 8Jx15 0mm offset with 20mm spacers front and 25mm spacers rear
- Nankang NS-2R 195/50 R15 tires
Best regards
Guido from SPS
Re: SPS Motorsport
#44
Wow, some very nice details on this one....
Guido, from your experience, what about practicality of a car that has some 3 times more power than stock.
Are stock gearbox, diff and axles up to it?
With a turbo, can you crank it up cold and start to drive slowly, or it needs to sit with the engine running for some time?
Re: SPS Motorsport
#45
Hi dboKlc,
we know which parts of the car break first if we add that much power and torque. But it is not the engine.
Gearbox (if it is 5-speed like in this car) and the differential are the weak points. The more You squeeze out the power and the more You use the car on track, the earlier gearbox or differential can brake.
The engine with its stronger internal parts is pretty reliable. It depends on the conversion You do.
Daily driving is no problem at all. You can use the car as every other standard turbocharged car. Just don't rev to high and don't give to much engine load when the oil is cold. When it's warm -> pedal to the metal. ;)
But we recommend a thicker oil (we use 10W60 for turbocharged NA/NB/NC) and an installation of an oil cooler to keep the oil temperature in a safe area.
Also we recommend a better radiator, a stronger clutch (absolutely necessary for a conversion like this) and a wideband o2 sensor for the ECU.
If You have more questions just ask me. :)
Best regards
Guido from SPS
